I know that 225/45/17 are perfect for my car but is it still perfect with my sportlines? yes or now and if not then what size do i go?
I have one true love in my life...And my girlfriend sits next to me in it
should be fine. the sportlines wont lower your car that much.
BaggedCav98 wrote:should be fine. the sportlines wont lower your car that much.
how low can you go with 225/45/17 with still being a daily driver?
well when i had 17's i was just barely above the tires in the front and in the rear, the lip was tucking the top 1/2in. of the tire. thats of course because of bags. when i had coils, i was lowered about 2 1/2in w/ konis
you'll be fine with sportlines and most tires in that size IF your car is bouncing and bopping all over the road...
in other words, make sure you have proper damping on those springs, not blown stockers.
Have you seen the turbo wagon?
14.069 @ 98.91mph
229.1hp & 261.7ft/lbs @ 6psi
no tuning time
u should be more worried with offset of the rim
u should def. be fine..i have 19s and my car used to have sportlines..i have a 215/35 but still..it didnt rub..so ull be aight..
Chad
Tell me more of why I should be more worried about the offset of the rim......
Offset will determine where the wheels are positioned laterally in the wheel wells. If you've got too low an offset, you will be hitting the fenders in the back and cutting up your tires. Basically, anything lower than about 35 may likely cause problems.
