I just bought some chrome rims on the weekend, and their pretty grungy... i used "never dull" to get the first coat of dirt off them, but their still not shining... i have some chroms polish, but i'd could go for a few suggestions on stuff that works well... thanks
Lees-ahhh
Brillo Pad, SOS Pad whatever you want to call it. Wet the rim and the pad and clean. I swear you will be amazed by the results.
![](http://img63.imageshack.us/img63/4900/kycavvie7oa.jpg)
Proud member of
JBOK (J-bodies of Kentucky)
Zach Hilton wrote:Brillo Pad, SOS Pad whatever you want to call it. Wet the rim and the pad and clean. I swear you will be amazed by the results.
that will work but you run the risk of scratching the rim.
Believe it or not it doesn't. Until I saw it done myself I never believed it. Once you finish just take some Mothers Chrome Polish to it and it gives it that added shine.
My brother doesn't even polish his rims anymore and just uses a Brillo Pad, the Chrome Rims are two years old and still look brand new.
Proud member of
i still wouldnt do it. its rubbing metal on metal. it could do damage
use secret agent wheel cleaner on it first.
then use mothers chrome polish.
makes the wheels on my s10 purrty
Sorry.....
You have been banned from posting on this site as of 2005-01-13 10:15:53.
This ban will expire 2005-01-14 10:15:35 Pacific Time.
Reason: Free 84 Cavi Drop Top!
Use Coca-Cola and some Tin Foil, not even the leading chrome cleaner will give you results like that, it will even remove slight surface rust.
that Coca-Cola and tin foil was tested on Mythbusters on the Discovery channel...and they found that it worked quite well.
this is my sig
