I have found a few I like; questions are:
18x7.5 with a +45 offset and then 215/35 tires...
Will they still tuck nicely with the air ride or should I lower the offset (if so what should it be?) and should I try and find an 18x7?
As for tire size, I know it may not be the "correct" size but I am looking to get the car as low as possible! How much of a side wall is on a 215/35/18?
-->Michael Ferrari
your going to get worse gas milage and its going to put more miles on your car
Doesn't sound like he's interested in either though.
Even with proper sized tires, can't you set the car on the ground with an air-ride system?
215/35/18 are small. I was comparing them to my 45/17s and they were a good 1/2 if not more shorter.
Nate
1995 Cavalier W/2k1 Engine
true i have air ride also and i dont see how this would help you get lower. even with a body kit. if you roll the fenders you will be able to tuck.
ya i have air ride and the wheels im lookin at gettin are 18x7.5 with 43 offset, im gonna get 225/35 tires for mine tho cause they are a litle bigger but not too much, later
pic coming soon
"Live Life To The Fullest" "Customize Everything"
