Ok I got a act 6 puck with exeddy pressure plate and a rhino pak slave cylinder my car is 2003 f23 with team green insert but when I try to drop the clutch fast it gets stuck put if I let it out normal it's works fine fluid full no leaks line in good shape like the slave gets stuck somehow I thinking maybe it needs greased up or something
I would start with bleeding it really good.
Probably a lack of grease on the input shaft or the wrong grease.
anyway i could grease it with out pulling maybe threw the little inspection hole
I have no Idea never tried.
