So I have a 97 sunfire and I am getting fed up with havin to bleed the clutch all the time. I have replaced the clutch, pressure plate, throw out bearing, and slave cylinder. Still having the same issue. It doesn't lose any fluid at all but somehow gets air in the system. Anyone have these symptoms before and fixed it? Thanks all help is nice
That's on the firewall correct? If so then that has been replaced.
It takes awhile to get it all bled out. How long has it been going on since the last time you refilled the system?
"In Oldskool we trust"
Z24Sunfire wrote:That's on the firewall correct? If so then that has been replaced.
Have you replaced the slave then? Or just the master? Tberes really only three places you can get air into the system. The master, the slave and the lines. If the slave and master are new then Id make sure youre lines are solid and tight.
As long as it's been going on it should have been bled out lol. Doesn't matter much right now cause the cavfire died tonight :/ deer ran out in front of me and when I hit the brakes it slid off the road right into a guardrail and not just slid down the side I mean passenger front tire hit dead even with the beginning of the guard rail. Hit hard enough to push the rim back against the door.
