Almost everything is turned up or down 10-20%. Your torque reduction / anti abuse in the trans is completely turned off. I can post screen shots of the stock tune to your tune if that would help. Seems like a safe mild tune.
Nothing seems wrong at all, just very safe and mild trans tune.
It is very similar to mine. Mine is currently exactly 20% turned up or down, but I'm making a lot less power than you are. I have my abuse mode still active, but cut down 20% as well. I'm probably going to bump most of mine up to 25%.
Edited 1 time(s). Last edited Monday, July 02, 2012 4:17 AM
-MD- Enforcer wrote:Almost everything is turned up or down 10-20%. Your torque reduction / anti abuse in the trans is completely turned off. I can post screen shots of the stock tune to your tune if that would help. Seems like a safe mild tune.
this is why we are all confused as to why his trans cannot seem to handle the power that is being put to it. id say hes around 325-350 HP, and it seems to me that the 4t45e should be able to handle that all day...
Not sure, but I like the idea of having the abuse mode kick in. I'm not really sure what all parameters it uses to determine when it kicks in. I think raising the line pressure more would help, also.
