2.2 shift cable - Transmission Forum
2.2 shift cable
Monday, February 14, 2011 12:47 PM
It came off today and seems that the cable end is broken and will not stay on. I've ordered a new one and was looking for any input on how much of a PITA this was going to be.
2.2 97 Cavalier......the "Crapalier"
Re: 2.2 shift cable
Monday, February 14, 2011 7:25 PM
what year car? in my 96 i ended up routing it OVER the rear seat foot warmer duct (factory is run under.) and you can't even tell they're there.otherwise its extremely straightforward.
Re: 2.2 shift cable
Tuesday, February 15, 2011 7:28 AM
97 2.2.
So will I only have to remove the center console and pull the carpet back? I'll probably pull the passenger seat to give myself more room.
Re: 2.2 shift cable
Wednesday, February 16, 2011 4:20 PM
if you don't want to cut the old cables, you may have to disassemble the duct work, which i didn't do.
Re: 2.2 shift cable
Sunday, February 20, 2011 5:49 PM
Replaced it today in about 2 hours. I cut the old cable out but ended up pulling the duct apart when installing the new one. It helped to have the passenger seat out and I cut the carpet in front of the shifter so I only had to pull up the inside corner of the passenger carpet. Before I pulled the old cable out, I tied a wire to it so getting the new one routed in the engine compartment was very easy.
The Crapalier is back on the road. $41 to fill it up today @ $2.96 per gallon! I remember when I could fill my Tahoe for $30!!
