Need some info - Transmission Forum
Need some info
Wednesday, February 16, 2011 7:58 PM
Hello hello. Now I am about to pick up a 2000 z24 to replace my 1996 2.2l body, my 2.2 is a fulley build motor. I would like to put this motor In the 24 with the 24 transmission, can this be done and what is needed.
Thanks
Re: Need some info
Thursday, February 17, 2011 12:05 PM
You'll have to use a 2.2 transmission
Re: Need some info
Friday, February 18, 2011 6:19 PM
does the 2.2 transmission have the same mounts as the 2.4
Re: Need some info
Friday, February 18, 2011 6:43 PM
2000 and up, the transmission mounts changed. You will either need to swap to a 2000+ 2.2 or weld in the mounts from a 99 and under. The mounts for the 2.2 and the 2.4 were the same mounts. The only difference is the bell housings for the 2.2 and the 2.4... and NO you can not swap bell housings. Don't even ask. 95-99 have different trans mounting locations compared to the 2000-2002
Re: Need some info
Friday, February 18, 2011 6:52 PM
i can get an adaptor plate to bolt the 2.2 to the 2.4 trans. would that work?
Re: Need some info
Saturday, February 19, 2011 12:28 AM
I don't honestly know. Hopefully someone else has a clue on that.
Re: Need some info
Saturday, February 19, 2011 7:03 AM
syn13 wrote:i can get an adaptor plate to bolt the 2.2 to the 2.4 trans. would that work?
2.2 - 2.4 izuzu trans are the same except for the bell housing, no adapter plate, just change bellhousing.
2.2 - 2.4 Getrag trans are the same except for the bell housing, no adapter plate, just change bellhousing.
http://www.weatherallsautomotive.com http://www.planethax.com/j-body
Re: Need some info
Saturday, February 19, 2011 7:57 AM
Thanks for the info.
So from what I can understand, my 1996 Ln2 motor can bolt up to the 2.2 getrag bellhousing that can then bolt up to my 2000 2.4 getrag. Is this right
