hey i currently have an 02 sunfire with 2200 OHV and 4 spd auto. im wanting to do a 3400 swap, and at the same time id like to do a 5 spd swap.
my question is, would i have to weld in some tranny mounts for the manual? that sounds like itd be quite hard because they have to be precisely in the right spot.
No welding needed just use factory mounting points. But.... as with any custom application if you need to weld anything like motor mounts or tranny mounts the only "exact" spot anything needs to be is where you choose, which can be virtually anywhere
Ryan Thompson wrote:No welding needed just use factory mounting points. But.... as with any custom application if you need to weld anything like motor mounts or tranny mounts the only "exact" spot anything needs to be is where you choose, which can be virtually anywhere
what do you mean factory mounting points? i thought there was supposed to be 2 mounts welded onto the driver side frame rail? which mine doesnt currently have.
Your original mounts will not work for a manual tranny.
Cut out your stock mounts and weld in the manual trans mounts in the correct places.
They don't have to be 100% exact, but get them as close to the stock location that you can. Measure measure measure.
Mike wrote:Your original mounts will not work for a manual tranny.
well how will i know where to weld the new mounts? haha,
does anyone have pics or measurements of them? cause i dont think ill beable to get a donor car or beable to keep it at my house.
Hmmm.... there's no pre drilled holes from the factory?
Ryan Thompson wrote:Hmmm.... there's no pre drilled holes from the factory?
i have no idea, i thought they were all welded on
You don't even need a donor car for
one of the mounts. But, you can just go to the junkyard, Find a car with what you need. Take everything that your car doesn't have, but will need to use a 5 speed. And put it in your car.
When removing the mounts from another car, Take measurements of where they are on the chassis, grind/cut/whatever them off. Use those same measurements on your car when welding them in place. Take some pictures if you want.
No pre-drilled holes for the manual tranny mounts (There may be on an automatic, but I don't recall). They are large tabs coming out of the frame rail.
Edited 1 time(s). Last edited Friday, October 01, 2010 4:15 PM
Mike wrote:You don't even need a donor car for one of the mounts. But, you can just go to the junkyard, Find a car with what you need. Take everything that your car doesn't have, but will need to use a 5 speed. And put it in your car.
yeah i was looking at that mount you linked. is that a good price you think?
and what do i need to pickup:
-pedals
-tranny
-shift cables
-shifter/center console
-rear trans mount
-cv shafts from same tranny
anything else?
Look on here I did a write up with the measurments and a how to---i think it was called getrag swap.
I think it is a little pricey for a piece of steel you could grind off at the junkyard for like $6.
But that's just me. TTR is a great company to go through in any case.
Aah guess I never knew that, but I have never owned a car that wasn't already a 5speed...
that really makes me want to buy a car that already has a 5 spd in it...seems like it would take me longer than desired to do.
Mike wrote:I think it is a little pricey for a piece of steel you could grind off at the junkyard for like $6.
Junk yards have less than $200 invested in an entire car, they dont have to make much on each part to make money back.
Ours our new, created from scratch, that is a complete ready to go solution, and no fuss.
-Aaron
www.TurboTechRacing.com
![](http://registry.gmenthusiast.com/images/turbotechracing/personal_pic.jpg)
Turbo Tech Racing wrote:Mike wrote:I think it is a little pricey for a piece of steel you could grind off at the junkyard for like $6.
Well, Of course junkyards get cars cheap. And even if yours is new, It doesn't really matter. You can find clean mounts all day. Someone getting that involved in a car will have enough common sense to grind off a clean, rust free mount. And how do you figure it is no fuss? You still have to prep the area, measure, weld it in place, clean it up, and coat the surface.
Personally, I will take the one extra step, and grind the mount off another car to save another $70. (And that is even with the current sale price. Wait till the price goes back up another $20)
^thats just personal preference.
I for one have to drive about an hour to get to the nearest yard that I can pull my own parts. Add in the time of me actually cutting that mount off the car, and its no longer worth my time. If I had spent the same amount of time working, I could have used that money to buy the mount and still make a profit. Not to mention some people are glad to pay extra for convenience. Again that all depends on your financial situation, but there is no reason to bash TTR's mount, the price is reasonable.
D.Simoes wrote:^thats just personal preference.
In addition there are NOT that many manual tranny J-bodys around. 90%+ were factory autos
-Aaron
Turbo Tech Racing wrote:In addition there are NOT that many manual tranny J-bodys around. 90%+ were factory autos
IDK about that figure.. just looking up 2000 Cavalier coupes, for example... 115,198 total made... 18,459 were 5-speed manuals, 66,123 were 3-speed autos and 30,616 were 4 speed autos. That makes 16% manuals...
John Lenko wrote:Turbo Tech Racing wrote:In addition there are NOT that many manual tranny J-bodys around. 90%+ were factory autos
16% is still pretty damn low, thanks for the info though. Always good to have accurate information.
D.Simoes wrote:John Lenko wrote:Turbo Tech Racing wrote:In addition there are NOT that many manual tranny J-bodys around. 90%+ were factory autos
Come on now guys, We are talking about a mass produced car... That's 16% out of how many hundreds of thousands? And if you are using the comp nine site, That also excludes sunfires IIRC. Which brings that number even higher. Just to humor you guys...
On average, There were about 200,000 (Cavaliers specifically, Coupes and sedans) produced each year (Some years were over 300,000). And on average about 20,000 a year going outside the states. And even with your average of 10% coming with manuals, Aaron. That is 2000 a year, For 10 years, making a rough 200,000 total with a manual tranny. And sunfires with an average production of 100,000 a year, And even less leaving the states. With manual transmission percentages hanging close to 20% during the mid 90's. So we will say just 10% came with a manual, even that adds 10,000 a year on to our total of 200,000 manual cavaliers. I'm sure John can agree with most of these numbers also. If not, correct me where I am wrong. But this proves 16% is still a large figure when talking about J-body production
My point is, There are a ton of clean junkyard mounts. It's not some uber rare part. Just don't try to play it off like they can't be found easily.
Also, I am not bashing TTR, and their price is not reasonable.
Edited 1 time(s). Last edited Sunday, November 07, 2010 6:35 PM
I did say that was just 2000 Cavalier coupes... not Sunfires.. not sedans... not Z24 coupes.. not convertibles (which were a very low % in that 2000 model year...).
I don't feel like looking up all the variants.. but the bottom line, as you say.. they're not hard to find.
John Lenko wrote:I did say that was just 2000 Cavalier coupes... not Sunfires.. not sedans... not Z24 coupes.. not convertibles (which were a very low % in that 2000 model year...).
You did say that, And I didn't note it in my ramblings. Though I do always trust your info, John.
