axel up grades...whats out there? - Transmission Forum
Sunday, May 09, 2010 7:21 PM
Broke my axels...boo I guess they aren't as strong as I was hoping.
I know Driveshaftshop.com makes them and they are local to me and I know TTR carries their axels...are there any other options? 800.00 for axels hurts the wallet.
Re: axel up grades...whats out there?
Sunday, May 09, 2010 7:37 PM
Stock axles are quite strong, they can take plenty of hp..... something else is an issue to why you are breaking them.
Sunday, May 09, 2010 9:01 PM
Isaak wrote:Stock axles are quite strong, they can take plenty of hp..... something else is an issue to why you are breaking them.
Sunday, May 09, 2010 9:05 PM
i doubt you are doing something else wrong. its just the car knows to take out the weakest link of the system which happens to be the axles. id rather replace axles than slip the clutch enough to pre-load the drivetrain to save the axles.
Monday, May 10, 2010 3:32 AM
I was driving down the interstate at normal speed headed back home from a car show. Car has only been to the track once this year and that was back in february. My guess with the whp close to 275 now something had to give.
Wednesday, May 12, 2010 4:01 AM
if they're gm axels there strong but aftermarket ones r weak as hell. if u broke a aftermarket set i would try some gm axels. u could prob get low mile used ones pretty cheap.
Wednesday, May 12, 2010 4:45 AM
I broke the GM axels and they only had 66k miles on them.
Thursday, May 13, 2010 3:33 PM
There are plenty of 3800 swapped guys on stock axles, I am one of them.... hp isn't what will break axles, torque is.
Thursday, May 13, 2010 3:41 PM
did you physically SNAP the axle housing itself or just brake a cv joint?
were you're boots torn at all and exposed to the elements at all? were they full of grease?
Don't know what ya got til they take it away...
Friday, May 14, 2010 6:52 AM
Isaak: my tq numbers are the same
Z yaaa: cv Joint is what broke the boots are not torn at all and the car is rarely exposed to outdoor anything.
Friday, May 14, 2010 7:37 PM
Then I am stumped..... I bet if you throw in another axle, and determine that it isn't binding and is straight, it will not break.
Monday, May 17, 2010 11:20 AM
I'm running Dutchman Motorsport shafts in my axles... but the CV's are from a Park Ave Ultra.
