Can you put the 2.3 flywheel in the 2.4 wiht 2.4 trans as long as you use the whole works? Flywheel clutch pressure plate ect.
97cavalier
I am using a flywheel off of a W41 in my 02.
whats the diff between the two flywheels (stock 2.4 and the stock 2.3)
is one heavier than the other?
If you are using a 2.3 Getrag flywheel it is the exact same as a 00+ 2.4 flywheel. If you have a 96-99 2.4 then I am not sure if there is a 2.3 flywheel that will match it exactly (maybe a 95 but not sure).
Last time I checked, my 95 2.3 flywheel was stepped like the 2.4. Pre 95 flywheels are flat. What are the weight differences?
Pre 95 and 00+ weigh the same. Not sure how much a 95-99 weighs but I assume its heavier.
