arrival_04_eco (green98cav) wrote:http://www.j-body.org/forums/read.php?f=2&i=338317&t=338317
Now we mark off the top of the shifter base and let the sparks fly. Make sure you have yourself a good grinder/dremel. They say to take off 5mm of material, which is fine on the two sides, but the front/back close to the mounting holes you want to take off as much as you can, I'd say at least 7-8mm. I dont have a picture to describe it, but when the shifter moves front to back, the ends of the pin holding the pivot to the shifter arm, come extremely close to the shifter base but doesn't touch. I lucked out and had just enough room. Probably why ppl complained of not being able to shift into certain gears, didn't remove enough material and the shifter would hit.
kris foutre wrote:In the post where he was grinding away excess metal from the shifter base he said that if you don't remove enough metal that certain parts may hit and not allow you to shift
