soo..i cant push my clutch in ...i noticed it when i was doing a motor swap..i got the car up in the air and relaized i couldnt push the clutch in..long story short put the new motor in and went to push it in and snap..it broke at the firewall..what would make the clutch not go in..no fluid or cuz the car was at such an angle?? i put fluid in it before i tried to push it in...
check the slave cylinder line. make sure you pull the clip out, and push the line ALL THE WAY in. it might feel like its in but make sure.
do you know y for any reason it wouldnt go in when nothing was touched ?
you said you did a motor swap... you leave the trans in?
I took the old motor and tranny out and put the old tranny on new motor....I used the same clutch and flywheel and ev erything off my old motor...I noticed it did this before I even took the old motor out...I coasted down the street to get to the garage I was goin g to work on it in..and it was fine..I seemed like as soon as it went up on jackstands it wouldn't work...I noticed there wasn't fluid in the thing u puut the fluid in so I added some...it was like tryin to push ur brake pedal without ur key turned itg was that hard and wouldn't move...then snap!
