Story: had the team green lsd put in and also put on a stage 3 clutch and pressure plate. The system has been bleed out but here is the problem when you push the clutch all the way to the floor it wants to grid like it isn't disengaging but if you don't push the clutch all the way to the floor it will shift through the gears no problem. It seems like the throw out bearing is over extending. Has anyone had this problem before? It all worked fine before it was taken apart.
keep bleeding it vac and by foot i did that in a balt with a stage 2+
see ya!
If it is bleed all the way... sounds like the flywheel\pressure plate is loose..........
Chris
'02 Z-24 Supercharged
the custom clutch was the problem...one of the plates was a touch to thick and scratching the fingers on the pressure plate.
Jbdy04 wrote:the custom clutch was the problem...one of the plates was a touch to thick and scratching the fingers on the pressure plate.
for the record what was the company who made the clutch?
