4T45E swap - Transmission Forum
4T45E swap
Sunday, June 28, 2009 3:03 PM
i did a search already on the ORG and all i came up with was a couple of guys debating what tranny has the better final drive ratio, what i need to know is if anybody has, or knows what is need to swap a 4T45E form an 04 alero into my 98 cavalier, im also asking if it will fit cause im putting the 3400 motor in with it. will i need to change alot of mounts, how much of the wiring harness will i need form the alero, can i use the same axles, knuckle, spinles, control arms ect. any links or info will be helpful at thins point thank -jh
Re: 4T45E swap
Sunday, June 28, 2009 3:19 PM
And on Aleromod, we all hate the ones equipped with the 3400 + 4T45E combo. Nothing but problems.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Re: 4T45E swap
Sunday, June 28, 2009 3:45 PM
what would be a better combo, my mom drives an 04 alero with that combo, it quick and smooth, what are the comon proplems
Re: 4T45E swap
Sunday, June 28, 2009 9:06 PM
don't everyone speak up at once
Re: 4T45E swap
Sunday, June 28, 2009 9:23 PM
Lower intake manifold gasket leak... transmission problems (yet the 4T40E, which is supposedly the 'weaker' one of the two, is far stronger). Overall less aftermarket support. Talk to a few of the guys on here who have done the swap though, it seems to work out well for them.
650 whp / 543 ft-lb
@turboalero
Re: 4T45E swap
Monday, June 29, 2009 10:39 AM
thats what this post is for but so far you the only one steping up with info, which i apreciate by the way,
