please help my friend. - Transmission Forum
Friday, May 29, 2009 4:59 PM
He has the same car as me 98 cavi z24 5 speed. well it started that his clutch pedal went to the floor and wouldnt come back up. so he brought it to a guy who aparently works on hondas. so he tried to change the master cylinder. nothing wrong with it so he changes the slave cylinder. is this correct? there two hydraulic cylinders or what?
MY question/problem is it wont go into reverse and its shifts very hard. i tried it and it like the clutch is not releasing and the car jumps forward a bit when you put it in gear. Maybe needs some more bleeding of the clutch? how do I do this?
Any help would help us out, thanks
Re: please help my friend.
Friday, May 29, 2009 5:10 PM
yes, two cylinders. usually, if the clutch need bleeding, the pedal feels really soft and sticks to the floor. try bleeding it anyway, and check the actual gear lube level. if it's low, drain it and refill it with synchromesh.
