I have a 2001 cavalier with a 2.2 L in it with the stock trans. My top cooling line is leaking from rubbing on the lower cooling line. My ? is how do I get the lines free from the trans it looks like a plate holds them on if I remove that plate will they come out. Thanks for the help.
http://www.j-body.org/members/image/whyte01cavy/personal_pic.jpg/
ya there is a bolt in between the two lines holding on the plate i believe a deep 10mm
8 psi with m62 and IAT under 100
alright cool so I just remove plate and the lines should come out great thanks alot guys
ya there will be a o ring on there you will have to replace
do u know if the o ring will come with the new hose or not, also is there a lot of fluid loss during this thanks again for the help
there will be a decent amount of fluid loss but nothing outrageous. Best thing to do is buy a couple of quarts from the parts store just in case and if you dont use them, then return them.
thanks for the help guys, one more quick ? my trans doesn't have a dipstick so just fill till the fluid comes out the check plug on the trans right. thanks again for the help
