Lately in the morning when I start my car and move it up towards the house, the reverse gear has been taking its time to get into gear, It normally would be like a 4 second delay. Now this morning it was about 5 degree and I went to put it in reverse, wouldn't go in, just revved up and wouldn't move, put it in park, tried it again, same thing, once more, and it finally budged after about 6 seconds. Just wondering if there is anything I need to worry about. The car is a 2000 cavalier, has a 2.2 and has about 102,000 miles on it.
All other gears work just fine when driving normal.
I was going to look into a change once spring rolls around. Being that the car is the age it is. What fluid do you recommend and just a pan and filter drop?
I wouldn't do a flush. Just a pan drop/filter change and Dexron 3 fluid.
![](http://i41.tinypic.com/i75ziv.jpg)
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
I've heard Hurst Trick Shift is a good fluid to use also....
any others?
I need a definite amount of what to buy,
part number for filter and amount of fluid.
Thanks for the help MadJack
stupid no edit,
anyways.
When you meant the parts counter person, are you saying dealership or just a typical autozone should carry the filter?
OK BACK AGAIN!
Did the trans flush about a week ago, went great. Fluid levels all good.
NOW
At WOT in 1st gear it will not shift into second until I let off the gas, it ran up pass the 6k mark on the tach today, figured it would shift, but hit the redline and bounced about 2 times, scared me sh*tless and let off. Shifts fine otherwise, and shifts fine at wot through 2nd-3rd.
What is going wrong now?
974drfire wrote:I wouldn't do a flush. Just a pan drop/filter change and Dexron 3 fluid.
Did you do an actual flush or just drop the pan and filter? A flush in an old transmission can make your problems worse, as opposed to a pan drop. It's starting to sound like you need a tranny, man.
I only did a pan drop, didn't mean to say flush.
I'll check into the cable adjustment and get back.
I didn't fix the TV cable yet, idk if it needs it or not.
But, went wot today and it didn't jump about 5600, running normal again...
What is going on?
