I'm looking to change the clutch and Flywheel for my 2001 Z24.
I noticed that the ACT GM1-HDR4 seems good, but noticed that the application's only for up to 99 models.
does that mean I can't use it?
Please help. Thanks!
well... if it says it will fit up to 99 models, then no, it will not work. not trying to be a smartass, but its common sense.
If this helps:
95-99 has the Isuzu transmission
00-up has the getrag tranny (better) basically, anything that will fit 00-02 should work for you.
![](http://i41.tinypic.com/i75ziv.jpg)
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
If it's the same as the 2.2, all you gotta do is change the flywheel to the 95-99 flywheel and clutch will work. Not sure tho bought the 2.4, i don't have any experience with that motor.
is it this????
ACT GM1-HDR4 CLUTCH KIT: CAVALIER/Z24/SUNFIRE 95-99
Advanced Clutch Technology for: Chevy Cavalier/Z24 2.3L 1995, Cavalier/Z24 2.4L 96-99; Pontiac Sunfire 2.3L 95 & 2.4L 96-99. (Kit comes with heavy duty pressure plate, 4 pad race disc, release bearing, pilot bearing & alignment tool.)
thanks. I already found out. Just that Gravana tuning listed it under the 01, so I wanted to confirm with al lyou experts
Now I'm thinking Exedy OEM replacement with a Fidanza 198241 flywheel
anyone have experience with tahat one or have comments about fitment? thanks!
It basically depands on what kind of driving you do, and what you use the car for...
day to day and some light track work.
