is my trans broken - Transmission Forum
is my trans broken
Saturday, January 03, 2009 1:05 PM
hey whats up guys im new to the j body world. I'm hoping you may be able to help me with answering some questions. I've got a 96 sunfire and recently ran in to some trans. issues. The problem is that when your going down the road in a straight line its good, but when you turn the steering wheel while the wheels are moving it pops like a 4wheel drive truck. strange right, at first i thought that it could have been the half shafts, so i bought and replaced the two. To my disappointment it didn't fix the problem, so now my question is my transmission blown or what else could be the problem.
Re: is my trans broken
Saturday, January 03, 2009 4:03 PM
are the shift realy long?
do you smell burned fluid?
how many miles?
when was the last time the fluid was changed?
Saturday, January 03, 2009 7:25 PM
it acts normally there's no smells nothing to make me say that there's a obvious problem , the only times it acts up is when you turn the steering wheel and the car is in motion . as far as the miles go its got 169xxx ,fluids are all fine
Monday, January 05, 2009 3:29 PM
I suspect you should check your CV axel joints, and if good, check your front wheel bearings. Good luck.
Monday, January 05, 2009 6:51 PM
replaced the axel shafts and wheel bearings are fine, another thing i hadn't mentioned was if the car is motion and you let off the gas pedal it makes a clicking noise
Tuesday, January 06, 2009 4:59 PM
Sound like your differential is going bad
Tuesday, January 06, 2009 5:24 PM
sorry if it sounds like a stupid question but aren't the differential and trans. the same thing
