Blew my tranny - Transmission Forum
Blew my tranny
Sunday, December 14, 2008 6:38 PM
So cruising down the Northern State Parkway and i hear clunking which i thought was a flat tire. I pull over, look at all 4 tires and none are flat. so i get back in my car, start her up and decide to drive slowly. I hit the gas andmy tach goes up, my speedo goes up, but im not moving. 4t40e btw. So im thinking snapped output shaft. Cause clearly the reluctor wheel is still registering with the VSS. But nothing is making it to the ground. No forward gears no reverse. When i put it into park it makes a grinding noise.
So output shaft yes? any suggestions?
Re: Blew my tranny
Sunday, December 14, 2008 6:41 PM
wow that sucks... it may just be a CV /jointshaft that you broke.. I would highly doubt you blowing a tranny just cruising unless you were running it really hard or doing neutral drops
LE61T PTE6262 Powered
Re: Blew my tranny
Sunday, December 14, 2008 6:43 PM
if it was a CV shaft then why would my speedo goes up?
Re: Blew my tranny
Sunday, December 14, 2008 6:54 PM
The VSS reluctor gear is on the differential, which sits inside the passenger side of the tranny. If the speedo is showing speed, then the problem is after the diff. After the diff are the output shaft, axles shafts and CV joints.
Re: Blew my tranny
Sunday, December 14, 2008 7:46 PM
i would think axle before anything else.. but I am rusty.. been outta the game a while
Re: Blew my tranny
Sunday, December 14, 2008 8:39 PM
Ok so i got back from work and crawled under the car. Passenger side half-shaft isnt connected at the transmission. I felt inside and it seems as though the shaft in the tranny is what broke as suspected. Wont know if the half shaft is still good till i get her home in a week but thanks for the tips.
Re: Blew my tranny
Monday, December 22, 2008 9:24 PM
bet no one sees this coming
tranny not blown, output shaft not broken, CV not broken
my half shaft CAME OUT of the transmission. The half shaft i installed A YEAR AGO jsut decidied to pop off the shaft. who woulda thunk it?
Re: Blew my tranny
Monday, December 22, 2008 11:16 PM
And Just HOW did it come out????
]:-> 287 TimeSlips In Hand. Car Still Runs Strong... 3 Differentials Later ]:->
Re: Blew my tranny
Tuesday, December 23, 2008 11:48 AM
NO FRICKIN IDEA lol
i was going stright on the highway so its not like i was doing hard cornering to pull it out. Myself, my stepdad and my mechanic friend all stood around scratching our heads wondering how it popped out after a year of being in.
no idea how
Re: Blew my tranny
Tuesday, December 23, 2008 5:48 PM
I had the exact same thing happen to my car after I put a pass. axle in it. I ended up having to put a new C-clip on and its beens fine ever since.
