Shifting problems 4T45 - Transmission Forum
Monday, December 01, 2008 3:04 PM
OK When the car is shut off. i start it, it will not shift from 1st to 2nd untill about 3500-4000K.. But uts like its the amount of time. I can floor it and will never shift, just bounce off the rev limiter. If I gradually accelerate it will shift. Its about a block, when I leave for work it shifts in front of the same house on my street. Now, Once this intial shift is done, it shifts at a normal RPM. although its a frim harsh shift. That in and of itself basiacllt eliminates mech problems such as the front pump. The car is shut off, the problem is back. I know these 4T45s are electroniclly controlled. My Z24 had a similar problem whan I forgot to plug in the IAC sensor after my CAI was installed. Anyone had similar problems? Any easy thing to look for?
Lets Get this New Forum Going!! We need some Q4/TC Gurus
Re: Shifting problems 4T45
Monday, December 01, 2008 7:52 PM
My 4t40 has a hard shift or two when it's cold. It doesn't shift until around 3500-4000 on those shifts but it's fine after that. Only when cold though.
Sounds electronic though..
Tuesday, December 02, 2008 10:17 AM
well Mine can be shifting fine. i shut it off literally for 1 second, it will do the same thing.. Only it takes alot longer to shift. Like a couple miles, as opposed to one block when cold. I'm just afriad I'll end up blowing my motor lol
Tuesday, December 02, 2008 11:07 AM
I would like to point out, she speedo does not work, the ETC light is on as well as ABS. The Speedo is plugged in.
