I Have My Transmission On The Ground, I Just To Replace The Spyder Gears! I Think We Pretty Much Put Everything Back In Place! Every Gear Goes In Good! The Thing That Confused Me a Liltle Before I Put It Back On The Car! When I Shift It (Every Gear Except The 1st) I Can Turn The Shaft That Goes In The Engine / Clutch With My Hand! Is This Normal?.. Or Should It Turn On The 1st Gear Like Every Other Gear?
.. n Another Quit Question.. About Shims On The Spider Gears, I Heard They Were Like 4 Different Ones?.. I Just Put The Same One Back In, ( Witch Is Probly The Smaller One Cuz There No Notch On it).. Theres Was a Lil Bit of Loose, But The Transmission Shop Told Me Is Has To Be a Lil Loose n Told Me To Put Automatic Full Symthentic Oil In It! ..
i! believe! its! time! to! get! a! new! tranny!
![](http://i139.photobucket.com/albums/q289/fast97z24/zya21kn7.jpg)
In the end, we're all just chalk lines on the concrete.. drawn only to be washed away.
It was workin before.. n' everythin looked good in it when i opened it! .. ?
