clutch master cylinder conection ques.... - Transmission Forum
Sunday, October 12, 2008 5:33 PM
just putting back together my 98 sunfire gt 2.4 where the cluth master cylinder connects to the slave(black conector) is there an o ring in the conection i noticed one laying on the floor after i took it apart, could have been from somthing else i had taken apart not sure, i tried the o ring in the coupler and the only logical place i saw that it would go was the groove that the "fingers" on the inside of the other peice lock into..........
Re: clutch master cylinder conection ques....
Tuesday, October 14, 2008 6:21 PM
There has to be an o-ring. I just put mine back together and noticed the same thing, an oring on the floor but did not seem to fit at all. So i connected it with out and o-ring and it leaks. Maybe someone can chime in with maybe a size or a part #. I will call GM tomorrow.
http://www.overkillengineeringmotorsports.com/
Wednesday, October 15, 2008 8:32 AM
Here is a pic of the one I just used, fits good. If you want I can send you one? I am going to order some from mcmastercarr.com out of viton.
Wednesday, October 15, 2008 8:35 AM
Thursday, October 16, 2008 1:23 PM
same as the one i found, thxs alot for the replies, just wasnt sure because i was having a realy hard time putting it together with the oring
Wednesday, November 05, 2008 2:38 PM
hey im goin through this same situation right now, where does the o-ring go???? can anyone help??
Monday, December 22, 2008 3:34 PM
i have a 99 z24 that has clutch problems where does this oring go? does it go where the two screw together or does that black plastic line seperate from the grey end somehow???
Tuesday, December 23, 2008 10:58 PM
i also have a question about said "o-ring"... I've been having a problem with losing pressure in my clutch for a while now and i have fluid leaking on the hose from the clutch fluid to the master cylinder. could this be due to a bad or cracked o-ring? and also it will run days where it holds pressure the whole time. when it does lose pressure i have to put the car in neutral and pump the clutch then put the car back into gear only to lose pressure again after driving in a certain gear for 30 or so seconds.
sorry to OP for the thread jack.
Under Construction
