Big izuzu problem, what a surprise - Transmission Forum
Sunday, October 12, 2008 9:09 AM
Alright guys, so after having the car parked for roughly 8 months even though I would tow it here and there (always in neutral), I went to move the car today in 1st, all was well. Following, tried to back up, car will not move out of 1st gear. I can put it in the 1st, 4th, and reverse positions, but all lead to the car still moving forward. In 4th the car goes under load and the revs come down as if the clutch is engaging, but the car does not move the slightest bit. The cables are fine on both ends, everything gravy there. Moved the selector brackets by hand on the trans trying to get in into any other gear, no dice. Popped the selector cover off, all looks well. What the @!#$ is going on here? The car was absolutely perfect when I put it back. All that pops into my head is shift fork fatality. Doesn't make much sense, tranny gurus please chime in! PS, it is a built izuzu with a quaife and cryo'd 2.2 gears.
Blew it up, build numbers coming soon
Re: Big izuzu problem, what a surprise
Monday, October 13, 2008 4:58 AM
shift rails\forks are @!#$.
Chris
'02 Z-24 Supercharged
Monday, October 13, 2008 8:29 AM
Understood, but from sitting?
Monday, October 13, 2008 2:12 PM
Did you move the selector by hand with the cables still hooked to it? I mean, it doesn't make sense to me that just sitting there would damage the trans. Mine sits all the time and it's fine, I leave it in gear otherwise the brake cable ties up and my back brakes sit there stuck when I try to move the car. But at one point my car did sit for several months without even having the axles in it, and it still works fine.
Monday, October 13, 2008 2:18 PM
Sounds like the shift select jumped out of the gate, leaving it stuck in gear.
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Monday, October 13, 2008 5:07 PM
time to upgrade!
Chris
Monday, October 13, 2008 6:27 PM
not with a brand new spec clutch you f23 whores. in all honestly, i'll have to go new venture. gotta see what the deal with this one is. i'll keep you guys updated, it cant be the end of it.
Monday, October 13, 2008 7:28 PM
good thing for the NVG then hey?
best of all, its damn near plug and play!
Chris
Saturday, October 18, 2008 11:27 PM
try to check your cables to see if one rusted some
Wednesday, October 22, 2008 5:52 AM
What up Pete, where ya been man?
