Replaced Clutch, Few Questions - Transmission Forum
Sunday, August 10, 2008 12:25 AM
I just replaced the clutch, now I went in to push on the clutch, it just sucks to the floor, I have to reach down to release it, is this cause I just need to bleed the system or what?
Replaced with Exedy clutch (there was an exedy in it already) its a 2.2L ohv.
2001 Chevy Cavalier (Sandrift Metallic) 8 OHV of raw fury!
Re: Replaced Clutch, Few Questions
Sunday, August 10, 2008 9:39 AM
grab it with your hand and pump the hell out of it, after 20 times, refill the master...
this is normal.
Chris
'02 Z-24 Supercharged
Sunday, August 10, 2008 11:32 AM
^Thank you much. I just wanted to make sure I didn't @!#$ up on the job and have to take the trans off. I did it on my buddys eclipse and the clutch still acted fine so It helps to have some extra info so I don't have to worry.
Thursday, August 28, 2008 9:36 PM
i am having the same problem with my car and i cant figure it out .. i bled the clutch a nice bit and still having a problem .. the problem i am having is if i leave it alone for like 10-15 minutes and get into the car ... i push the clutch peddle in with my foot and it will go right to the floor .. keep tapping on it and the flude builds up . but when i stop and leave it along for a bit welll i am back to the same problem with the clutch peddle going ro the floor.
Friday, August 29, 2008 4:20 AM
Taetsch Z-24 wrote:grab it with your hand and pump the hell out of it, after 20 times, refill the master...
this is normal.
Chris
Some times it take doing it more then once.
Chris
