getrag troubles - Transmission Forum
getrag troubles
Wednesday, May 21, 2008 2:11 PM
Parts:
  • f23 getrag transmission
  • spec stage 3 clutch
  • team green lsd
  • ttr trans race mounts
so i've run into a snag while replacing a hole in my trans case. received a donor trans case and newer rebuilt f23 getrag transmission w/ low miles. trans was in working order when engine was pulled in march. mine had about 98K so thought was safer/easier/smarter to do now. installed lsd into trans. replaced stock clutch for spec stage 3. replaced throw out bearing with newer one. put everything back together. fill trans w/ fluid. checked to make sure shift cables are connected correctly. bled the clutch.
Problem:
gears shift easily with car turned off. gears shift semi easily while car is moving after shifting into second. does not want to go into gears while car is stopped/parked or going from reverse to 1st.
Solution:
any ideas?
_______________________________________________________________________
my carDomain updated 3/6/07 Boosted at B-day!
Re: getrag troubles
Wednesday, May 21, 2008 8:45 PM
how is peddle feel?
Chris
'02 Z-24 Supercharged
Re: getrag troubles
Thursday, May 22, 2008 4:07 AM
Taetsch Z-24 wrote:how is peddle feel?
Chris
peddle is great.
Re: getrag troubles
Thursday, May 22, 2008 4:05 PM
have someone push the peddle down, and look under the car and see if the plate is pulling off the disc.
Chris
Re: getrag troubles
Thursday, May 22, 2008 5:03 PM
Taetsch Z-24 wrote:have someone push the peddle down, and look under the car and see if the plate is pulling off the disc.
Chris
skunk says thanks.
Re: getrag troubles
Thursday, May 22, 2008 11:57 PM
Chris
Yeah didn't even think to look through the inspection hole to verify that the tob was actually working properly. Thanks for the suggestion chris.
