Hi my Transmission just died and its really hard to find one where i live there are almost only automatics around and no Standard Transmission i found a 92 cavalier fits on my engine but doesn't bolt on my frame so i cant put it there so i need to know if anyone here already did this kind of rebuilt and if its possible there both Isuzu i'm currently dismantling my Sunfire apart to get the other inside if there is anyone with some info id like to ear from you Thanks.
ok still no replys but I have taken apart both transmission and they are Almost exactly the same
Found that the Diferential Gear from one as 69 teeth(Sunfire 95) an the other 68teeth(92 cavalier) but on both Shaft the other gear that connect's to it as 19teeth
and i found that on the primary shaft there is one gear i dont remember wich one but on one there is 20teeth and the other as 17teeth
i did not have time to look on the other shaft and count on the gear that connects to it but will do tomorrow
if anyone as some info dont be shy and post thank you
