WHERE CAN i GET ONE FOR A 2000 Z24?
ok, sorta off topic a bit, but what is the best thing to run with a turbo setup? I'm assuming just the stock flywheel is good, but just checking if there are other options.
We carry the SPEC and Fidanza
-Aaron
www.TurboTechRacing.com
![](http://registry.gmenthusiast.com/images/turbotechracing/personal_pic.jpg)
unorthodox makes an aluminum flywheel, but on the website it's for the 96-99 2.4. which means isuzu, not 00-02 getrag
might want to call them and see if they could make one for the getrag?
Last we checked Unorthodox does not make one for the getrag
SPEC and Fidanza are the only 2....
-Aaron
Just had a friends Spec/Fidanza go down this weekend. Same problem as ever other one I have seen break. Stock flywheel FTW.
mitdr774 wrote:Just had a friends Spec/Fidanza go down this weekend. Same problem as ever other one I have seen break. Stock flywheel FTW.
when was it manufactured?
![](http://www.radford.edu/~cebrown/solo2av2.jpg)
-Chris
^^^ it doesnt matter, they're all junk.
![](http://i139.photobucket.com/albums/q289/fast97z24/questionmarkzyaaaasig.jpg)
Rollin' on question marks since 07.
Do the fidanzas have problems in this application?
I have an 04 cavy with a hahn stage 2...
Stock flywheel
I have a saturn sl2 with nitrous, it's faster than the cavy, the saturn has a fidanza and I have never had a problem...
![](http://www.myslips.com/eslip/blackbirdracing.jpg)
Spec and Fidanza are the same flywheel. They are junk. Keep the stocker and be happy knowing it wont break on you.
yea, and why dont we just keep the whole engine stock while were at it so itll last longer...
i have the fidanza flywheel, works GREAT and has done so for YEARS..i recomend it to all
^^^^^^^^ i will not second that I have fried two both were in the car less than three months.
Looks like i'm going RE-finished OEM for my turbo build.......or brand new OEM....hmmmmm.....
Got my unorthadox flywheel Looks great seams like a lil better quality than fidanza also it weight in a about 9.5lb.
where the flywheel bolts to the crank is also a lil thicker.
Thrice . wrote:Looks like i'm going RE-finished OEM for my turbo build.......or brand new OEM....hmmmmm.....
go new. our flywheels are so cheap its silly. i got mine for $40.
where did you get your unorthadox ? i would like to compare one to my fidanza while i have it out
