Already so after browsing around and not finding my problem id figure id ask to see if anybody can help. My problem is that if my clutch pedal is all the way to the floor my car is hard to get into gear when standing still, upshifting and downshifting. It all does it when moving. I tried double clutching but that doesnt help. And sometimes it grinds a little going through the gears even if the pedal is through the floor( clucth obvisouly) so is it my clucth going since i do believe its the original with 116,000miles on it . Or is it something else maybe cheaper or maybe more expensive. Id figured id ask because I dont want to order the clutch and flywheel and find outh thats not it. So any help is much appreciated
Could be the disc on the clutch sticking to the flywheel, also the syncro's could be bad in the transmission. I would say those are the only 2 things that could be wrong.
-Aaron
www.TurboTechRacing.com
Your clutch isnt fully disengageing. Check your fluid level in your clutch, inspect the line going from your clutch to the transmission for leaks, and if everything checks out and its still happening. Then your throw-out bearing is proboly shot.
