good mods for a auto tranny - Transmission Forum
Thursday, September 20, 2007 12:29 PM
yo i searched for this and found nuttin but i have a 01 cava and it has a auto tranny in it ... so yesterday i was drivin it when it dropped all its oil and the engin locked up and now i have a hole in my block... and i think that my tranny is shot too so i was wonderin if i could swap out the auto for a manual... then i read a auto is better for boost because there is no loss of psi so i might wana keep the auto and if so what good mods are there for the auto tranny... because i might as well do this wile im puttin a new gngin in it ... tear
IF YOUR GONNA GO DOWN ... THEN GO DOWN IN FLAMES
Re: good mods for a auto tranny
Thursday, September 20, 2007 1:40 PM
Autos are good for "turbos" not "boost" in general, because there is a constant load on the engine keeping exhuast flow up which helps spool-up. The 4t40e and pretty much any of the gm auto trans are blessed with being much stronger than what GM rates what the transmissions internals can handle stock. The downside to these transmissions though, are that they are heavier, cause a greater whp loss than a standard trans and the gearing is awful. However, if you are planning for more than 200whp (as it would appear), then the gearing will be much more fitted to that kind of power level.
Good, simple mods for an auto trans would be
-higher stall torque convertor (such as a Yank)
-and the B&M shift plus or the Autotrans interceptor (or HPTuners if you decide to go that route)
"Youth in Asia"...I don't see anything wrong with that.
Thursday, September 20, 2007 1:53 PM
Don't for get about the Solid Tranny mount we just released
-Aaron
www.TurboTechRacing.com
Saturday, September 22, 2007 11:58 PM
yea the yank converter and the b+m shift but if you put it on keep it there i can mess thing up . now i constenly shift hard and cont get it to stop and my ets wont come one another good thing would be to get a transmition oil cooler that helps alot.if you wont to go deep you can get some better bans and plates the mount i need
Wednesday, September 26, 2007 3:35 PM
x2
Thursday, September 27, 2007 10:00 AM
yank 3000 stall convertor
team green lsd insert
b&m shift plus or auto trans interceptor or HP Tuner
blue plate clutch packs
heavy duty input and output shafts
high performance valve job
TTR auto tranny mount
there is alot more out there if you just look. the things listed above are what i am doing to my 4t40e
