I just remembered... if it looks like this:
I have 1 extra from my box of connectors when I did the new wiring harness on my car.
I just need to solder some leads on it (all I have is yellow and blue wire for it, but I'll keep the yellow one on the right pin) and I can mail it to you...
I'm showing that its the same plug as the coolant temp sensor plug, so if all else fails, you may have to sacrifice that sensor for your speedo.
Not sure how to get it translated over to GM-speak (it should be the same part # though...)
no edit button:
I'm showing that its the same plug as the coolant temp sensor plug, so if all else fails, you may have to sacrifice that sensor for your speedo, yellow wire on plug to purple wire on VSS, brown to yellow
If its the 99 listed in your reg, per my service manual, its the same one, same part # even.
your not trying to plug the reverse light plug into the VSS are you ?
both a 2 pin plugs and look similar
[quote=97cavie24ls(™)]your not trying to plug the reverse light plug into the VSS are you ?
Nope... That sensor is not the issue.
I have no plug to plug into the VSS sensor as the Isuzu-based connector is not compatible with my new Getrag VSS sensor.
