I got the b&M shift plus and i have it all hooked up. I love the feel of it. Its definitely the best upgrade i've gotten for 50 bucks ahha. I did have a question about this item though. I have a no trac light, which i know is normal, read it on jbody forum. After driving the car i notice that the rpm's will jump when i leave off the gas(not breaking).. they quickly make there way down to 1000 and then jump inbetween 1000 to 1300 to 1000 to 1300 and then they stop after like 5 times, is that normal? Also, when i leave off the gas but do not break, i hear a small squeel, like a burning belt. The only thing itouched was the pcm when i changed the wires around, i was thinking the squeel would be the torque converter, what do you think? Oh, and i have the b&m if setting 1.
I took it for another spin, this time i had it set on option 2. I still have the squeel and the reving problem, but now i also get the check engine light. Is this normal as well ?
Also, whenever i had the B&M hooked up i had a rocky start? like the car started and the rpms would drop n it would die out. I didnt have this all the time, sometimes it would stay on but they still died. What did i do wrong?
- 2003 CHEVY CAVALIER LS SPORT ECOTEC -
- Current Mods -
-- Vibrant Exhaust & DC Sport Header --
-- Lower Motor Mount & TTR Upper Motor Mount --
-- B&M ShiftPlus & Vibrant Front STB --
-- K&N Typhoon Short Ram Intake --
RIP DAD<3 We love & miss you so much!
i'd check your wiring. it sounds like one of your connections is wrong
and there's no need to post multiple times about the same thing. the reason that no one has responded is probably due to the fact that no one has experienced your problem and they don't feel like guessing at a solution
I connected the red with black to the red wire of the b&M and the light blue with white to the black wire of the b&m. I noticed there are two red with blacks and two light blue with whites. I tired both reds and got a check engine light still. I stuck with the same light blue with white. I thought the wiring was right? I have it unhooked now and i dont have no check engine lights. any suggestions?
- Current Mods -
