I have a 2000 Sunfire SE 2 dr, which has 272,xxx km's on it and is having computer troubles. I know for a 2001 Sunfire SE 4 dr with 98,000 km's on it that I can get for cheap. Both cars have 2200's and 5 speeds. My question is, can I take the Engine and Tranny out of the 4 dr, wiring harness computer and all, and just bolt it in plug it all back together and it run perfect? I shouldn't have to do any modfiycations to anything right? Just plug and play?
sorry, I meant can I put all the 4 dr stuff (engine, tranny wiring and computer) into the 2dr and everything be plug and play?
Come on guys, somebody knows this. Someone told me that if I change Engines, I have to change wiring harness computer BCM, even the gauges.I can't see this being correct, as everything is identical between the 2.
i changed motors in my 96 nd it was pull out motor plug in motor if they are both the same and have all the same sensors u could just change the computer if it's the same plugs don't quote me i'm not a mechanic just tryin to help
4 door civic on the way
i need a daily driver
