What model of transmission do I have? - Transmission Forum
Monday, April 09, 2007 2:58 PM
Ok, I should be slapped, and thrown up in some tree someplace for asking such a question. Believe it or not, I use to know things like this but since my J has been less of a priority for me I have forgotten a lot of things..
I didn't find anything in the search, so who knows.. Maybe this will help more people in the future..
I have a '99 2.4 5-speed Sunfire. What type/model of transmission do I have T340E? (or is that just the auto).
Also, Does anyone have a part number of a rebuild kit for it and a reliable resource to order it from? Specifically, I need synchro's.
Thanks!
-White
You might be a Civic driver if you concider going on a diet 'weight reduction'. <a href="http://www.homestarrunner.com/mrshmallow.html">...That's right the moon... </a>
Re: What model of transmission do I have?
Monday, April 09, 2007 5:13 PM
T2940 Isuzu comes to mind..? ...That doesn't sound familiar enough.
-White
Monday, April 09, 2007 7:29 PM
95-99 were isuzu's, if thats what your asking buddy........
Monday, April 09, 2007 7:37 PM
You have the isuzu tranny.
Monday, April 09, 2007 9:27 PM
and the auto is the 4T40E
Tuesday, April 10, 2007 6:02 AM
So it's just Isuzu? Without the fancy model number adding to the ease of finding parts?
...If it's just Isuzu, maybe that's why I couldn't remember a 'model number' cause I remembered Isuzu...
-White
Tuesday, April 10, 2007 8:07 AM
Tuesday, April 10, 2007 9:01 AM
I'm sure you're right, but why am I remembering the MK7 to be the 3-speed auto 2.2 tranny?
-White
Tuesday, April 10, 2007 9:30 AM
I found the part number for the '99 5-speed 2.4 transmission: 97131255
Looked the number up on: http://www.gmpartsdirect.com - $1800~ (YIKES!)
I also found an excellent resource for parts and numbers in another thread at the bottom of the first page.
http://www.j-body.org/forums/read.php?f=41&i=23769&t=23766
Sooooo good! w00t
-White
Tuesday, April 10, 2007 11:22 AM
WhitePhatt wrote:I'm sure you're right, but why am I remembering the MK7 to be the 3-speed auto 2.2 tranny?
-White
i dont know. the designation for the 3 speed auto (2.2 and 2.4, doesnt matter its the same) is 3t40, or th125.
Tuesday, April 10, 2007 10:12 PM
So, just for clarification's sake..
The 5-speed Isuzu tranny's model is MK7, and it's denotion for the 2.4L is 3T40 or TH125.
The 5-speed Isuzu tranny's model is MK7 is the same for the 2.2L.
They are exactly the same despite having different part numbers (which still sort of makes sense because they bolt to different engine's).
TRANSAXLE ASSEMBLY
2.2L Eng P/N : 97131256
2.4L Eng P/N : 97131255
So, I guess the next question I should ask is are they REALLY identical?!? Even down to the bell housing?!? If I bought a 2.2L MK7 (97131256) tranny it would bolt up as a direct replacement to my MK7 (97131255).
It just seems too good to be true..
-White
Tuesday, April 10, 2007 11:16 PM
no no no.
all transmission were the same for 2.2 and 2.4, except bell housings.
MANUAL TRANSMISSIONS
manual 5 speed trans:
95-99: isuzu mk7
00-05: getrag (i believe the designation is mm5, but dont quote me on that)
AUTOMATIC TRANSMISSIONS
auto 3 speed:
89-02: 3t40 also called the th125c
auto 4 speed:
95-05: 4t40e
to dissect gm's designation system for auto transmissions:
4(designating 4 forward gears)
t (t or l, t for transverse FWD or l for longitudinal RWD)
40 (torque rating)
e (if there's an e, its an electronically controlled trans)
now, between the 2.2 and 2.4 isuzu manuals, there is a slight difference in the gear ratios, and the bell housings are not the same. BUT the transmissions are the same. all this information is also in the faq if you still arent quite sure.
Wednesday, April 11, 2007 7:26 AM
Thank you soooo much Rich!
That's exactly what I needed!
w00 w00
I will also take a look at that FAQ to see what other jewels of information I can gather.
...I wonder how difficult it is to swap bell housings... Probably not worth the hassle..
Thank you Thank you Thank you
-White
Wednesday, April 11, 2007 11:53 AM
Rich Grayo Jr. wrote:no no no.
quote]
eeeehhhhnnnnttttttt. try again! the 2.2's had a slightly different gear ratio. pretty nice gearing actually if you combine it with a 2.4
engine like i did! he he!
Wednesday, April 11, 2007 12:02 PM
95-99: isuzu mk7
auto 3 speed:
auto 4 speed:
95-05: 4t40e
40 (torque rating)
Wednesday, April 11, 2007 1:26 PM
Pwn'd
-White
