tranny swap - Transmission Forum
tranny swap
Sunday, November 26, 2006 1:51 AM
im going to be doing a manual swap on my 96 Z and was wondering how much the reflash is at GM, or what would happen if i didnt do it..
Re: tranny swap
Thursday, November 30, 2006 6:24 PM
well seems how no one else likes to answer these swap questions i guess i will
the reflash is normally at any dealership an hours labor charge....$65-85 dollars depending on the dealership
as far as if you don't get it done you will be throwing a code for all of the trans shift solenoids.....just get the re-flash done...its worth it...........
also the rev points are different, you will idle higher then needed and also when shifting from one gear to another you will stay at a higher rpm b/c the computer does not know whats going on b/c the speedo is reading but the trans is not shifting
if you have any other Q's let me know
(also i have done the swap so this is not a guess)
R.I.P. Micheal Geyman 2006
Re: tranny swap
Thursday, November 30, 2006 11:19 PM
thanx man, but i ended up just buying a 5 speed car with a blown motor, in better shape then mine, so im just gunna put my motor in that
