ok i got a 2004 cavalier with the 5 speed. when i push the clutch in it goes straight to the floor and stays there untill i pull it back up i checked the hydrolic fluid and it is full any other ideas
Bad slave cylinder or clutch master cylinder. OUCH - expensive, hope it's still under warrenty.
Don
Leaking line or air in the line, try bleeding it first before you assume anything else is bad.
