When I pull the pass side axle will I loose any trans fluid and if I do will it be alot.
thanks.
you will lose all of it.... as thats almost the lowest point in the transaxle.... Drain it first then replace the fluid with new.
i had the one side of my car jacked up when i did mine and i didnt lose a drop. i guess it depends on how your car is sitting.
Wojo wrote:i had the one side of my car jacked up when i did mine and i didnt lose a drop. i guess it depends on how your car is sitting.
I think you should check your fluid level.
M.
