Reciently i have been loosing my clutch and i thought it was my clutch res. might have had a hole in it.... but the first time it was the seal that the tube fits into the res. and got air into the lines no big deal just bleed the cltuch right? Wrong me and my pops did that and i put my car in reverse pushed the clutch in and the car slowly started to move when i had the clutch pushed in.... turned the car off and noticed a nice size puddle coming from my tranny. So i was wondering if it is a hydrolic leak or something else....maybe a gasket?
need some help guys
is the fluid coming out of the inspection hole? if so it's the slave cylinder.
14.82 @ 97 mph
check the clutch hose near the big wiring harness. Today I was driving home from work when my clutch started doin the same (in 1st, not reverse), I had to keep messin with the clutch just to get it to go, and was holding up traffic. Finally when I was in line at a busy intersection, it went out completely, to the point that it wasnt driveable, I had to push it off the road (across 3 lanes during rush hour) where I could take a look at it, and the hose has 2 holes worn in it from rubbing against the wiring harness. just need a new hose and fluid. Nothin major, but definitely a PITA.
