Hey I found a deal on 2000 clutch and flywheel. But, I have a 99 will it fit? Also though my tranny needs rebuilding so I'm thinkin bout the getrag swap. Will it fit the getrag? And the clutch is a centerforce dual friction does anyone have this clutch and how is it?
ok sounds good? But what about the slave cylinder? Will it work w/o it or do I need it and how hard would it be to swap it in. I ask b/c if the price exceeds that ok a regular clutch kit then its not worth it unless I just do the getrag swap which I'm not sure about yet. Still researching.
I am currently using a 2.3 clutch and flywheel on my 99 Z24 with Isuzu trans. The tranny is out now getting rebuilt so I am upgrading to a 00-02 Spec stage 2 clutch while it is out. All the measurements are the same except that the 2.4 pressure plate is 1/8 taller than the 2.3. ( could have something to do with wear too ) I haven't changed the slave cylinder
Jason
99 Z24
Racers Edge
Johnny Mack Turbo Systems
Engineered Performance
