Automatic switching to a manual - Transmission Forum
Monday, June 19, 2006 12:38 PM
A 1996 Sunfire GT automatic how hard is it to switch it to a manual and will everything be alrite when it is switched and wut all is needed... Because I know one guy that switched his automatic over to a manual and he has no mount for his shift cables and stuff
Re: Automatic switching to a manual
Monday, June 19, 2006 1:51 PM
Well, there are a TON of threads on this if you had bothered to search...
You will need:
Transmission
Flywheel
Flywheel Bolts
Clutch Kit
Front and Rear Transmission Mount Brackets
Front and Rear Transmission Mounts
Drivers and Passenger Side Axle
Shift Linkage
Pedal Assembly (Can just use clutch pedal if don't mind a big brake pedal or cut the brake down)
Clutch Master Cylinder
Shifter Assembly
And other miscellanious parts. Please search for a full list of what you need and what it involves. There are literally hundreds of posts out there about transmission swaps.
Saturday, June 24, 2006 6:34 PM
i changed a 2000 grand am motor automatic into my 5 speed cavy
