5th Gear Speed - Transmission Forum
5th Gear Speed
Thursday, February 02, 2006 2:35 PM
Does Anyone Know How Fast You Can Go In 5th gear
Re: 5th Gear Speed
Thursday, February 02, 2006 2:49 PM
Since you have a governor on your car, you will go 108.
As for what the actual gear will do for you it depends on how much power you make to actually move the car along with exactly what transmission you have in your car.
For example, say if you have a 2002 2.4L 5 Speed Cavalier. Put your car in 5th Gear and drive... when you reach say 3200 RPM look at the speedo and see how fast you are going.... lets just say it says 70 MPH in 5th gear @ 3200 RPM.. double the RPM 6400 RPM apx the redline on the car and you will come up with a 140 MPH that you can do in 5th gear. There is also a factor of not having enough power to make you go that fast......
Re: 5th Gear Speed
Friday, February 03, 2006 11:55 AM
Karo (Car Customs) wrote:Since you have a governor on your car, you will go 108.
That factor is key cause it probably wont work like that, seeing as how the wind or frictional resistance or whatever increases like a banshee past 100.
Madjack wrote:Like I said before, building an engine like ours (2.2 or 2200) is a painstaking chore , since there is so few custom made parts. It's frustrating to me too, but that's what I like about doing this engine, it's the challenge.
Re: 5th Gear Speed
Friday, February 03, 2006 12:05 PM
all i know is that ive taken my 97 2.2 manual tranny to 108 in 4th hit the governor and still have 5th gear
http://www.cardomain.com/ride/2090440
Re: 5th Gear Speed
Friday, February 03, 2006 12:06 PM
I know that you hit the rev limitor in first at 30 mph 60mph in second 90mph in 3rd and then the governor in 4th
Re: 5th Gear Speed
Friday, February 03, 2006 4:32 PM
I have the power since i build the motor for it and i made a VSS override
Re: 5th Gear Speed
Friday, February 03, 2006 6:17 PM
Well then take it to a track and find out.
Re: 5th Gear Speed
Friday, February 03, 2006 6:49 PM
My 5th gear has pulled me to 135mph, and it still had a few RPMS left till redline. I do not advise going this fast. My car was still pulling hard at 135 too, but thats with a turbo. I don't know what a stock engine could go, I doubt much, if any over 120.
Re: 5th Gear Speed
Saturday, February 04, 2006 4:48 AM
Thanks Guys
