I just installed the auto trans interceptor. My car seems like it is taking off in third and will not break the tires loose for nothing. Iwhen i get on the gas it seems like the tranny goes in to neutral and then it hits the rev limiter. I know the auto trans work and works well my friend has one on his 03 cavi. dose any one know what is wrong. please help
Your autotrans interceptor does nothing but make your shifting more on point by increasing your line pressure. If you are having problems with it hesitating or seeming like it doesn't want to shift, it sounds like you have other issues.
Take the interceptor off though and drive with it to see if it does it still but I doubt it's the interceptor.
When I first put mine on and was testing it, it shook the hell out of the car when I turned it up high, but nothing lke what your describing. If you take the auto trans off and your trouble stops, then its probably turned up way too high.
I just purchased an auto trans. I was wondering if the guys that use it could suggest which of the 16 settings in the directions i should put it on or if you have any other recommendations. I was gonna go with 8. Thanks.
Matthew Thompson wrote:I just purchased an auto trans. I was wondering if the guys that use it could suggest which of the 16 settings in the directions i should put it on or if you have any other recommendations. I was gonna go with 8. Thanks.
There is no real recommendation that anyone can give you, it's really up to how you like it and how high you want it. If you are satisfied at that setting, stay there.
Thanks for replying. What setting do you like? I just dont want my car to be shaking all over the place like that one dudes when I first put it on.
Dale Jr wrote:Thanks for replying. What setting do you like? I just dont want my car to be shaking all over the place like that one dudes when I first put it on.
Mine is set a little bit before halfway
Trans clutxhes are worn time to rebuild the trans.
Tach Out Motorsports
Option D Inc.
