How do you change the tranny oil from an 04. I searched, but maybe I just didnt use the right words. Thanks for any help
It is on the bottem hump. It will be a hex.allen key. It will be on the drivers side.
simple drain and fill, every 50k miles?
would recamend filing with royal purple cause it help casue i had regular fruid in mine and when i blew the trans i put purple in and it made a better and smother shift.
12.7@110MPH with 10PSI.
DeadBob wrote:Well, I feel stupid right now... I just made a post about this in Maintenance about an hour ago...
Anyway, before I go pulling random bolts, is the bolt below the barcode in this picture the drain puug?
No. That is the one when you go to fill it up you need the car level, and put fluid in, once it starts coming out it is full. The one you need to drain it is lower (very bottem.
