i know this has probably been asked before but i just need a quick yes or no. I have an '05 cavy, is there any difference between the transmission in my car and a 97 z24 tranny? there both 5spd. would mine hook up to that 2.4 motor?
nope eco-tech is different from the dohc2.4 i think.................
so i will need to get the tranny from a 2.4 ?
The bell housings are different between every engine in the cavaliers 2.2OHV, 2.4 and 2.2 eco. Also 95-99 used a different brand trans than the 2000-05 getrags. Axles are both the same
-Aaron
www.TurboTechRacing.com
Hey turbo. are the mounting and housing dif. for the 00+ trans for the 2.4. Well I guess what I need to know is will a 2k tranny fit in a 99 body. I have a 2k motor sitting in the car right now. with a pre 00+ tranny bolted to it, but that tranny took a dump. So I'm needing to find out what is what. Cause I intend on buying brand new. When the time comes.
2Blue Cavy wrote:nope eco-tech is different from the dohc2.4 i think.................
Not to be a dick but the correct spelling is ECOTEC
Turbo Tech Racing wrote:The bell housings are different between every engine in the cavaliers 2.2OHV, 2.4 and 2.2 eco. Also 95-99 used a different brand trans than the 2000-05 getrags. Axles are both the same
What he said ^^^^
ok so is the mounting any different for the trannies? heres the deal im putting a built 2.4 motor in my car, '05 cavalier, from a 97 z24 and im just tryin to figure everything out before i start replaceing everything, just wantin to make sure i have everything i need
chris Lineback wrote:ok so is the mounting any different for the trannies? heres the deal im putting a built 2.4 motor in my car, '05 cavalier, from a 97 z24 and im just tryin to figure everything out before i start replaceing everything, just wantin to make sure i have everything i need
The lower mount is the same on both engines. The upper engine mount is different 2.4 and the ecotec. Also the trans from the 97 needs different mounting braket locations, than the 2000+ the actual bushing inserts are the same however.
-Aaron
I have been told by someone before that a 03-03 ECOTEC uses a f23 getrag tranny. Now I have a 2002 2200 cav with a f23 getrag in it? WTF is going on ?and can i use this in my eco swap?
same transmission different bell housing on it. So the eco is not interchangable with a 2200
-Aaron
so this motor and tranny isnt really a basic swap? what all am i gonna need to do?
