Tanny interceptor help - Transmission Forum
Sunday, July 31, 2005 4:21 PM
i just add the tanny interceptor from rk sport witha2.4 problem is hy hp gone up but my 1/4 mile time has also it was awfull i was down to nearl 17 sec in a 1/4 i took it out and i gained
what i like to know is that is has the setting for the tourqe converter delay do i want to add delay or take it away i had very littel delay set should i go for more delay or not who used it and how did they set it up to make it work good i want to know before i go back and make a fool out of myself again
make it loud and make it low
Re: Tanny interceptor help
Monday, August 01, 2005 5:05 PM
Egad...
I'm trying to understand what you're saying... but I just can't get it.
So, you installed the Autotrans Interceptor... and your hp went up. How do you know that? Did you get the car dyno'ed? Or are you relying on a butt dyno here?
1/4 mile time... what was it before AND after?
The settings on the Interceptor are simple.
The TCC delay is the amount of time it will wait to lock up the torque converter clutch. You can set it from "as soon as possible" to "take as long as you want". Taking shorter is good for fuel economy, but bad for hard parts in the tranny, exhaust (engine/transmission clunking around, unless you have aftermarket engine mounts), etc. Longer is better for power, but not really on the racetrack. As far as I know, that control is hidden inside the case now, but that may have changed again.
The Line Pressure adjustment is the main one. The higher you set it, the harder and faster the shifts are going to be. Again, if you don't have aftermarket engine mounts, the poor engine & transmission are going to slop around in the engine bay.
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/misc/redsig.jpg"></a>
Monday, August 01, 2005 6:27 PM
i got a beltronics fx7 and it reads the acceration g and with input of the car it can calculate the hp and when i used the tranny inceptor the hp reading increased
