are the axels from a auto the same as axels from a manual? And is it true to swap a auto to a manual, that u have to weld the tranny mounts on? i dont get that?
And if there is anyone out there that can give me a GOOD list of parts im going to need to do the swap id appreciate it...
btw im swapping a 95 2.2 auto to a manual 5 speed...
thanks
SPONSORED BY: CAVALIER EXTREME
No, the axles are different.
Auto trans has one big mount in the middle of the frame rail on the driver's side of the car. 5 speeds have two, one at the front of the rail, one at the back. The auto mounts are ALL the same... and are totally different from the 5 speeds. 95-99 (Isuzu) 5 speed is different than the 00+ (getrag) 5 speed mounts. You have to get the mount brackets, and weld them in. You also have to cut off the auto mount for clearance on the tranny.
There are lists in this forum all over the place, I'm not going to do that much work for you
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/misc/redsig.jpg"></a>
