Eco2.2 w/ 3T40 - Shift Problems - Transmission Forum
Friday, June 03, 2005 1:27 PM
My sister's car is a 95 Cav with a 2.2 and 3T40, 170K miles on it. Just the other day it started having trany problems.
Symptoms: Does not shift up.
If you accelerate easily (20-60% Throttle) it will not shift. Sometime (not often) it will shift from first to second. It will not shift up to third.
If you accelerate hard (70-100% throttle) it will shift as normal. From first to second at ~30MPH, and second to third at ~55MPH.
Steps Taken Already: Checked the fluid level. Noticed it was rather brown (not terrible, but not good). So I dropped the pan, replaced the filter, and filled her up with new fluid. I followed the procedures in a Chilton book (which all seemed logical).
Status: Still has the exact same problems as when I started, although shifts seem to be more firm (probably the new fluid).
Any suggestions on things to look for, common problems, past experiences with the same symptoms and resolutions?
Re: Eco2.2 w/ 3T40 - Shift Problems
Friday, June 03, 2005 1:35 PM
first its not an eco
third, the throttle shifter linkage or watever its called is sretched out.
-Borsty
Friday, June 03, 2005 9:41 PM
My bad. Didn't think about it when I typed the title.
Thanks for the suggestion. Someone else said to check the same thing today.
I'll swap in a new cable tomorrow and see how it runs.
