I blew my engine last week and im trying to fix it, but i ran into a problem, i pulled the motor yesterday to find out that when the motor let loose, (and rod went flying) it put a small pencil sized hole in the case of my transmission. (leaks fluid) i need to have the car Running by tonight. HOW CAN I FIX THE HOLE??? could i just JB Weld it?? and what would be the best stuff to use to clean off the tranny fluid??
Sorry, man, the only way to fix it is a new tranny casing. Better off just getting a trans from the yard. PC11 (better than JB weld and works on wet surfaces too) might get you back and forth to work for awhile, but you'd better start saving to fix it right, cause that's only a temp fix.
<img src=http://ourworld.cs.com/jwithspray/Jbeier_sig3.JPG>
you can always use some jdweld for temp stuff like that
2000 Dark metallica green cavalier. (2.2 2200) pace setter 4-1 header, magna flow cat, dual quad tip dtm muffler, 1800 watt stereo with satalite radio, momo 16in rims, from rk sport strut bar, rear vibrant strut bar, indeglow gauge cluster along with matching hvac panel, clear corner lenses, altezz tails, vibrant wai, carbon fiber oem style hood, rsm lightened crank pulley, MSD Ignition coil packs, RSM Vortech Supercharger 8psi
"Disarters are just another star falling in my yard."
find some marine tex its kicks jb-weld but .. plus you can sand it and make it look like its supposed to be there.
<img src=http://domestictuners.com/banner.jpg WIDTH="400" HEIGHT="75" /img>
Hit 200 NA it broke once, Hit 213 it broke again,
Hitting 300 NA is further away than I thought.
Since your trannie is aluminum you could have it wielded, I think that this would be possible since it is only a small nich
'99 2200 LS CX1 Sport
