I have and 03 ecotech cavalier and the clutch pedal lets out really high. is there anything that can be done to get it to release earlier?
nope, there is no way to adjust it.. You're just going to have to get used to it. It's an issue I complain about quite often... it's probably the thing I hate most about this car...
Member of
NEJBODY.
so there is no threaded rod on the master cylinder to adjust? or is there and you just cannot adjust it?
![](http://img641.imageshack.us/img641/1227/sig1i.jpg)
2000 Camaro V6.
| SLP Loudmouth | CAI Intake | HID's |
The hydraulic clutch in the getrag is self adjusting. Go get the clutch pipe TSB performed at your dealer, it helps alot with the clutch pedal feel and engagement.
SPDDMON wrote:The hydraulic clutch in the getrag is self adjusting. Go get the clutch pipe TSB performed at your dealer, it helps alot with the clutch pedal feel and engagement.
Yes it did... for about two days. Then it grabs all the way at the top again... pedal feel is better but it still grabs way too high.
Member of
NEJBODY.
its all Jbody common problems.
But its the same on SRT-4... my friend complain about it to.
we dont have a baby clutch on GM. Its really not like Mazda. I so have trouble releasing the clutch pedal on my brothers Protegé... way to early for me.
My Car Specs
Club J-Body Montreal Forums
yea but i just put a new stage 2 in and its still the same. when i first got my car a year ago it engaged at the middle of the pedal travel. what is this clutch pipe thing? is it for all the getrag trannies? and will i have to pay for it?
2000 Camaro V6.
MatMan wrote:yea but i just put a new stage 2 in and its still the same. when i first got my car a year ago it engaged at the middle of the pedal travel. what is this clutch pipe thing? is it for all the getrag trannies? and will i have to pay for it?
could be do to the thickness of the spec 2? I know their discs are marginaly(sp?) thinner.
Thiinner?? my was thicker. I'm in the process of sending my back. They gave me a #. My spec 2 clutch was fcked. Couldn't shift gears.
Nate
![](http://img151.imageshack.us/img151/2818/cavysig8qb.th.jpg)
1995 Cavalier W/2k1 Engine
Incorrect pedal engagement is usually due too the pressure plate. I've done several aftermarket clutches that had horrible pedal engagement. Swapped in a different clutch without changing anything else, and it totally went away.
Curtis
91' Turbo Z24
http://www.turboz24.com
Mine did the samething the peddle used to be half way up, just put in a stage 3 and now it's all the way up, makes me look like a idot when I stall at a set of lights
